I've been thinking about doing that,seeing you have a 51 as your avatar do you happen to have a picture of the mount area or do you remember how it mounts? The 50 mount sits on top of the member, the 51 mount has to have a offset weld to it to keep the transmission at the correct ride height. I measured the distance from the center of the output shaft of my old unit to the center of the tunnel before removing it and duplicated it when making mount adjustments, the 51 mount in stock form raises the trans too much, it hits the floor plan.
