As far as noise, and/or longevity, lots depends on:
1. The present condition of your existing crank gear, which is not mentioned; &.
2. Who manufactured your present crank gear, which is not mentioned.
3. When faced with unknowns, new non-metal timing gears may be a better temporary choice if noise alone is a factor.
4. If noise "plus' longevity is a factor, you could replace the crank gear and install a new "matching" metal timing gear, with both manufactured by Mr. McEachern.
5. Most chose the cheap route and keep their fingers crossed that they never have to get towed because a hungry 80+ year old metal crank gear with barbed wire type teeth ate an innocent new non-metal timing gear while sight seeing 150 miles from home.
Just one opinion.
