Do you have the correct intake on that engine?In 37 the intake gen mount is a bit higher.
I like that word, (Package in USA) Where was the belt made, Cucamunga or someplace? WaltI have a stock '49 F1. The 53" water pump/generator belt I tried to use from Macs, is labelled 53", but is shorter and won't fit. Macs 55" belt, part# 40-8620-S, is actually 53" and fits perfectly - a friend bought it for his 36 and it is too small. My fan belt needs to be 34" and, again Macs belt, part# 21A-8577-S labelled as 36", is two inches shorter and does the job. Packaging on both belts says 'Made in USA'. ???
