Replace rear motor mounts
Zax40
Is it possible to change the rear motor mounts one at a time with the motor in the car and no frame spreader?
I have changed the rear engine mounts in my A's a few times, and it was not necessary to spread the frame.
I did a comparison between an original set of Engine Rear Support Cushions A-5092 Inner and A-5094 Outer that were made by Firestone. The Firestone cushions were laminated rubber with a one ply cloth inner layer. The original Firestone cushions are thinner than the rubber reproductions. So I abrade some rubber off of the thickness of the inner reproduction cushions, about 1/16" to 3/32".
You can see the original Firestone Cushions on Vince Falter's Ford Garage https://www.fordgarage.com/pages/aenginerearsupportcushions.htm
