johnr9q@yahoo.com
My ignition switch came with no key so I bought the following:
https://www.snydersantiqueauto.com/...hm.htm?type=merged&sterm=&searcht=A-11575-ERM
The Picture is of the one I took out. The new one has two terminals one marked coil/acc the other Bat. The old one had only one wire coming to it (I assume it was from the battery) The section of the new switch that comes out of the distributor has a single wire, does that wire go to the terminal on the switch that says coil/acc and the existing wire (That I assume is from the battery) hooks to the Bat terminal on the switch. What confuses me is the wire coming from the distrubutor goes to the coil terminal on the switch but I see nothing that actually goes to the coil. Thanks again (This is probably a stupid question cause I see no other way to hook it up, Sorry)
