Replace 1157 with LED
10gaugemag
1957 F-100 FWIW.
Has anyone replaced their 1157 bulbs with equivalent in LED and are there an issues such as rapid flash, stop flashing or just stop illuminating etc??
You will need a flasher that is compatible to LED bulbs. Also need to make sure everything has a good ground! Leds will do funky things with "dirty" grounds. By funky things I mean half lit, lighting when the next door light is turned on. Bottom line, just have good grounds!
