Hey boys, thanks for the suggestions- wow! there has been a lot of responses. I am a machinist myself, but do not have access to a cylindrical grinder, hence had to farm the job out. We, the machinist that had the woops moment, and myself have had a good old discussion re. repair of this. He didn't even know it was steel; thinking he'd have to metal spray it. Sleeving is out- no way you could pass a sleeve over the end journal, let alone the lobes.We sort of agreed that slowly building up the damage with mig, allowing time to cool between passes, would give least amount of deformation. [as JWL suggests] As he said, he has the undamaged half of the journal to set up off, all good in theory, but I'm still concerned about maintaining perfect concentricity of each lobe. Then I, like Bruce, thought of JB weld, or some sorta epoxy. We used to use an epoxy at work called Devcon? I think, which was supposed to exhibit exceptional wear properties, so thought I'd throw this out to all you learned fellows on the 'barn to see if anyone had a 'magic' solution.
As Kurt says it is his problem- well, I'm afraid old boy it is also my problem. **** happens, I just want to fix it, move on, and assemble this engine.
Jack E sure thing, you are so correct, however, first thing is to find another steel camshaft in good enuf nick to regrind, then ship it to the States, wait an eternity for Tony to work his magic, and get it shipped back. I'd prefer to have a go at fixing this one first before I follow your suggestion. But you are right....
Thank you boys...
