I am rebuilding the drivetrain on my 1930 Sport Coupe. I wanted to replace/rebuild the universal joint. The current joint on my car is the earlier riveted type which cannot be rebuilt. I found a later original joint that could be rebuilt and wanted to disassemble it for a rebuild.
The first thing that needs to be done is to remove the C Clips that hold in the bearing caps. I read in several forums that you should use a thin blade screwdriver to pry up on the clip and remove it. This is impossible! The clip is too strong and fits too tightly in the grove. I decided to cut the clip with a cutoff wheel and was successful in removing the clips.
The other issue is removing the bearing caps from the yoke. On a modern U Joint, you use a hydraulic press to press out the joint. The Model A joint is designed such that the caps must be driven out of the yoke with a punch. If the cutoff wheel is used to cut through the cap completely, the cap can be punched out easily.
Just thought I would pass along what I have learned.....
