Removing Snap Ring
sunnyorm
tehachapi
ca
how can i remove the bearing snap ring, on a 39 transmission main shaft. without using the special tool?
Thanks
Get in there and pry it out with a flat blade screw driver. Getting it in again isn't as easy.
The tool you need for this is under $10 at any Sears. If you are going to fool with these transmissions, it is certainly worth it IMHO.
