Removing seized Kingpin.
Torchie
I need to remove a seized kingpin from the 41 ford car chassis that I am working on.
Anyone have any favorite techniques that they can share?. I do have access to a press if necessary.
Thanks for the response's
Torchie.
I am working on fabbing a jig for doing this. I based it in the KRW fixture, with the main change being a slip fit to the pin for use in a press instead of being threaded. I am making it so it will keep the pin square with the press. I will have to make a different one for each major change Ford made to the spindles as some of the angles and setbacks are different. Rod
I once needed 20 tons of pressure to press out a kingpin on a 55 F 100. I think that a BFH will bugger up the spindel or axle so that you will need to replace something. Take out the axle assemble and strip it down so that a machine shop can press it out.
If you do not have access to a KRW tool (or equivalent) it can be done with a BFH. I have done many (prior to acquiring the KRW tool) utilizing the hammer (4#) method.
From my experience, once you can get the pin to move up a little, tap it back down. Hammer it back up a bit further the next time, then back down again.
It'll come out... just be patient.
Kube. Are you recommending the use of heat as well or no heat and just an armstrong BFH method?
I have found that heat is not of any particular aid here. To get both the axle and the bushing to grow enough requires a LOT of heat, something I am apprehensive to apply to a 75 year old assembly.
I am betting others have used heat... their experience???
Is it stuck in the axle or (spindle, probably unlikely) ?
Suggest heating the king pin & axle boss a dull red. Let it cool for few hours. Use Kroil on king ping & boss id. Let it sit an hour or two. 20 ton press, prefered or BFH should do it.
Actually I believe that it is stuck in the spindle as the lock bolt would keep it from spinning in the axle. With the front jacked up and the tie rod off there is no way that the spindle is allowing the drum to turn to the left or right. Other side seems to work fine.
Thanks for all the response's. I believe that I will try the armstrong-BFH method first.
The only disadvantage to using heat is in not knowing how to do it. The objective is to expand the "holder" without expanding the "holdee". This requires a rapid heating technique accomplished with maximum rose-bud sizing and, sometimes, a pair of torches.
Slow heating with "normal" torch methods will only serve to expand all components at about the same rate and do little.
thre is such a thing as a king pin puller there are two typs 1 .screw thread 2. hydl. may be you could borrow one from a shop that does truck work where you live
Sounds like it stuck on the bushings. Heat it up and pump grease into the zerts. Watch out for hot grease flying out . Won't take much to melt the gummed up joint.
You can also get stuck kingpins out if its a complete car using a bottle jack or portopower against the weight of the car but you still need a rosebud.
I run into this on everything from stuck king pins on old fords to bulldozers and backhoes.
50 years working on old cars gives me a lot of back experience on what works & what does not. This is just to say that what worked last year, does not work today...go figure. Using torches to heat is always the first on my list......and if does not dislodge the part....time for step II. The heat is great as the # 1 step because it does 'something' to help 'unglue' two adjoining metal parts through either expansion or breaking down rust. Mashing at red hot metal may be more harmful since one may be 'riveting' metals together, so working the cool metal is in order. Presses and BFH with patience is the definite next step. I guess we are ALL in the same boat.....Robert
Always used the BFH. Cried a lot but always got it out.
I am laughing ONLY because there is soooo much truth to your statement.
Once I had acquired that KRW tool, it made me wonder how I did all those pins without it.
Yeah, younger and more stubborn no doubt...
i just did mine last week, wouldn't budge with a 8 lb sledge, put heat on the axle and got them started with the 8 pounder then finished with a 4 lb, it wasn't bad but you need heat or a proper puller
