Rex Smith
All the bolts holding my gas tank in are seized by years of rust. I saw one post that said to use heat, however I'm not too keen on using heat near the gas tank. I'm also a little skeptical that I'm going to get all the bolts out even using heat. This truck is so rusty you can't even tell what color it used to be.
I can use all the advice I can get before I embark on this and mess things up.
thanks
thanks
