Removing Radiator
TudooR31
Having a wild time removing radiator on my 31. (replacing 4 blade fan with new 2 blade) Thought I would have it boiled out while apart.
Seems it doesn't want to twist enough to clear the radiator tabs between the frame & fender. Would removing the shell and/or thin rubber pads under tabs give it move twisting room? I have the hood, front apron, headlight bar, water pump removed now.
Thanks
:confused:
Word of warning. When you have the shop boil out your radiator do not let then pressure check it. The Model A coolant system is non pressurized. They can blow your core out.
