I am having trouble removing my worn out “modern” valve guides. I have been soaking them in Troil and hammering on the head of a 5/16” bolt that is inserted inside the guide. I have beat on it extremely hard with a hefty hammer, but it has not moved. Hard enough to wonder if I am mushrooming the top of the guide.
I am afraid to use heat on it because of all the oil that is nearby.
Looking for ideas??????
One idea from the forums was to drill and tap for a 7/16-14 thread and then pull it out with a threaded rod. Anyone ever try this? Or maybe use a long 5/16 inch threaded rod down through the guide with nuts and washers on the bottom and pull up from the top with a coupling nut? Would it break? Something would have to give.
All ideas welcome.
All ideas welcome.
