Cracker39
After reading about the potential hazards of aftermarket in-line fuel filters, mounted using clamps and rubber gas line tubes, I decided to go back to the original fuel line on my indented firewall '31 Tudor. I've been driving the car a fair amount lately on rough roads, and the clear filter shows no contamination. The clear filter is a definite advantage in that respect and I'm hoping that this means the tank is relatively clean. That said, does the side-mounted sediment bowl on the carburetor do a good job of trapping contamination from the tank? I know that it was Henry's original design from the start (---sediment bowls) but I've also read a lot about aftermarket fuel filtration systems that others have installed.
