1931 flamingo
Purdy: That's what I did back around '58, still have them.
Paul in CT
Paul in CT
I had trouble sleeping the other night, so at 3 in the morning I went to the garage and pulled my head. I wanted to pull the engine, but ran out of time this summer. I used my homemade head puller, which is the same style as our club's puller. I think Rainmaker Ron designed this. This was the first time I used my puller, and I'll make a couple minor changes to make it easier to use. I'll weld the bolts to the spark plug bases, so they can't turn while tightening the nuts on them, and they can't all into the cylinder with the nuts off. The 5 bolts on the plate have spacers and nuts on the bottom side, which I'll also put a small tack weld on, so I don't need to use a wrench on the bottom.
I've never had the head off my engine, but it came off without too much trouble. Once it was raised up an inch I still couldn't lift it, so I had to wait until morning when Fleet Farm opened, so I could buy 5 long bolts with full length threads. The only bolts they had with full length threads were carriage bolts, so I bought 5 of them. I only needed to use 2 to push on the studs in the center row of the head. These carriage bolts were long enough to raise the head completely off the studs. I'll either grind the heads of the carriage bolts square to match the underside of the bolt head, or I'll weld a hex nut on the round top of the bolts.
Where was the garage Brian?
