Removing ER brake actuating lever
PC/SR
Decided to do brakes before touring season gets underway. The right side emergency actuating lever will not slide off the shaft. The bolt is loose, and the lever is loose and rattles around on the shaft and will move to the end of the shaft, but stops dead and will not slip further off the shaft. I wonder if the woodruff key got cocked or something? Any help, tip, tricks advise most welcome. Thanks to all.
