Removing drum from hub '40 Ford 1/2 t PU
jackstevens
I'm replacing front hub on this PU and need help on best way to save old drum. I understand the drum can be bent etc if not done right.
Also, how to include an image on my ID and these messages. Thank you.
turn the drum with the studs faceing down . now with a die grinder a.k.a cut off wheel cut the heads of the studs off. now with a drift drive the studs out. if you don,t have a die grinder center punch the stud heads & with a 1/2 drill bit drill about a 1/4 inch & drive stud out. if you press or hammer the studs the other way you in large the holes in the drum as they are sweged. i am not good at explaining things hope you understand what i said
Look on the left side of the black band above, click on User CP and a
menu will appear, Settings & Options, click on Edit Avatar. ;)
I use a 5/8 deep hole saw. It slips over the stud and removes the swedge. The cut off swedge will start turning as soon as it is free. The turning prevents the saw from going too deep. It does not need to be a hardened saw. The swedge cuts easily.
Same here
