So there's the right way to fix this and then there's the quick way. The problem is that the linkage (between the spark control lever, at the top of the steering column, and the ball at the end of the upper plate on the distributor) is the wrong length. It's too long. There can be lots of reasons for that. The spark advance control rod, part A-9757, is supposed to be just under 17" long (not counting the spring-loaded caps), so perhaps yours is too long. The lever arm at the bottom of the steering column and the control rod it attaches to are supposed to rest at a particular angle, so perhaps yours points too far toward the side of the car.
The right way to fix it is to deconstruct and measure and figure out which component is out of spec, and then replace it with one that's correct. This is often difficult to accomplish due to parts scarcity, or reluctance to mess with the steering column.
The quick way is to get
one of these, cut some length off your spark control rod, insert this in the middle, and adjust it so the rod is the right length for your setup. Be aware that replacement control rods are not available from any source at the moment.
