Tom Wesenberg
I was working on a carb the other day and the top come off easily, but the venturi was stuck tight in the bottom. I used a propane torch to heat the cast iron around the venturi for about ten minutes, then ran cold water through the center of the venturi to cool it. The venturi slipped right out.
I'd bet dry ice on the venturi would do the same, but I don't know where to buy dry ice locally.
