You can also use an old head stud and nut.Thread the nut halfway onto the stud,the screw the whole thing onto the pump shaft.You want to bottom the two shafts out against each other.The nut is just to hold them together and keep them in line.When you hit it you want the energy to go from one shaft to the other,not through the threads.Hold the pump hub in one hand,palm up,with your fingers straddling the middle,with the pump hanging down.Now hit the stud like you mean it.Don't fool around with a bunch of tapping or with a little hammer.Use a 3 pounder.A lot of times it pops off with one hit.
