V8COOPMAN
The one pictured clamps to the hub center. The back disk is split to fit behind the wide part of the hub center. The front disk holds the back pieces together. Why is this one not okay?
IF your hubs/drums are actually installed on the axle tapers as tightly as they ARE SUPPOSED TO BE, you would be an extremely lucky man (if the threads on those two hardware store bolts and the female threads in the puller) don't wipe themselves clean. That tool will sometimes remove the LOOSE drums that were never installed tightly-enough as suggested by Ford. Like Clint Eastwood said........."Do you feel lucky"? Everyone with any REAL old Ford experience will tell you the same thing I am! Just look at the strength and heft built into this thing, below. Those threads are designed to be cranked-down on. DD
