Removing 1930 front fenders
I finally removed all the bolts, I didn’t see where to remove the one with the yellow arrow. Is this necessary to remove the fenders? Also do I need to remove the rear fenders to jack up the front of the body or is it not required? Still not to sure where it was suggested to lift the front of the body with a 2x4, I assume like I have pictured. Probably making this out to be harder than it is but I don’t want to screw anything up.
If you're referencing my post, your picture is not showing a 2x4 under the front body cross member. I place a floor jack below that "body" cross member, measure vertically from the jack's saddle to the underside of the cross member, cut a 2x4 to that length, place it in position, and slightly jack upwards. This way you can do it by yourself so you don't need someone else to strain their back and you're not rushed to slide the fender out.
