johnr9q@yahoo.com
I want to replace the front crank shaft oil seal so I need to remove the timing gear cover. The engine is installed in the car. I removed the bolts that fasten the yoke to the timing gear cover and the seven bolts that secure the cover to the block. I hit the cover where the generator mounts with a soft hammer but it didn't want to give. What should I do? Also, the cover bolts have holes in the heads. Am I supposed to run wire thru them? P.S. I did jack the engine up a little.
