Babyboomerboy
Can anyone tell me the easiest way to remove the speedometer gauge from the dash? I thought I had a broken speedometer cable but I changed that and the speedometer still doesn't work. Thanks
I haven't yet had the pleasure of tackling this project.
But I will eventually, my speedo reads 10mph when the car is parked.
Are you sure the speedometer cable is spinning when the car is moving? If not, did you check the driven gear on the trans. end of the cable when you changed it?
If it's a plastic one the teeth can easily wear down and not turn the cable.
My first guess would be to get a rough idea of the location of the gauge cluster back-side mounting screws by looking at photos of similar ones. Ebay probably has some listed for sale with several photos for each.
Disconnect the battery, use some tape & a pen to label everything you disconnect, round up a small mirror and a fluorescent/LED worklight to see around corners while you're upside down under the dash, and go for it.
