Remove Lever From Parking Brake Shaft
johnr9q@yahoo.com
I pulled the pin out. I tried to use a puller, no luck, I beat on it, no luck. The shaft turns with difficulty, I think I should replace the bearings?
Why are you removing it? Make sure it's free,and squirt a little oil in it now and then.Tightness is not critical there.
Keith True, Thanks, I'll do that. (I like taking things apart, when I was 10, I took apart an alarm clock, when I put it back together, I only had three pieces left over, needless to say, it didn't work).
