A AM3334 Member Nov 18, 2023 #1 Do you have to pull the box on 1933 pickup to get gas tank out? Does the filler neck need to be removed to get it out?
Vics Stuff Senior Member Nov 18, 2023 #2 Yes you do need to pull the bed. The tank sets on top of the The frame
A AM3334 Member Nov 18, 2023 #3 That means the filler tube has to come off or can it be pulled up with it on after the bed is off.
