matchlessman
I'm doing a complete timing gear change (worn cam gear, pitted crank gear), including the plunger spring in the timing cover due to the cam knocking sound. My question is, what's the preferred method for removing the old crank gear and installing a new crank gear? I realize I'll have to lift the engine slightly and drop the oil pan to get the old crank gear off. Am I likely to need major heat to get the crank gear off? Is there anything special about putting the new cam gear on?
Ken
Eastern Ontario
Ken
Eastern Ontario
