drolston
Backed out the set screw about 1/2", but door lock cylinder is still tightly in place. It is the original kind with the flip down keyhole cover that I want to retain. So how to remove the lock cylinder without destroying the bezel?
I want to avoid removing the door panel, if possible. But if that is the solution, so be it. With the door panel off, can you get to the end of the square lock shaft to tap the lock cylinder out?
Tried liquid wrench, tapping the edges with a wood shim, and a pretty good tug with a lock pick hook, to no avail.
When I get the lock cylinder out, is there any way to get new keys made for the original cylinder? The original keys are lost.
Or, can the tumbler be set to match the new ignition key?
