Removal rear radius rods
toms32
Can some one out there tell me if I have to remove the rear drums to get at the bolts that hold the rear radius rods ? Will I need a puller to remove the drums ? Thanks Tom
Yes you will need to pull the drum. The two radius rod nuts are shown in the picture, with the cotter pins.
And yes you will need a puller. This is a generic puller and it works just fine. There are pullers specifically made for the Model A.
MANY thanks for the info. Tom
1955cj5, do you know what make your puller is? I have a puller like that but it has shorter links and I would like to get some longer links and possibly a longer screw for it. My puller has no name on it.
Tnks, Ken
Randy, thanks for the info. I'll stick w/what I've got for now. I have made extensions using 1/2" NF rod couplings and wheel bolts, like this:
I was given one of those hub pullers but have never used it. I always wondered if part of it was missing, seem like it should have something to keep it from slipping out off under a lot of tension.
