Remote gas tank and electric pump
I have done several gas tank moves on model A's.
I use a 16 gallon fuel cell and mount it with 2 complete encircling steel straps under the rear of the car behind the rear end. If you have a rear mount spare tire, the installation is almost invisable.
I use a Holley electric fuel pump with a rollover switch and an Aeromotive bypass type regulator.
The fuel cell has provision for a gauge if wanted.
Love to see some pics of your setup. Also want carb are you using with it? Several people have said the factory carbs won’t work with a pump. Assuming there pump has to much pressure.
With ANY pump, you should use a regulator.
Bypass type regulators are the ONLY kind that will hold constant output pressure and volume under all fuel delivery conditions.
The common "dead head" type regulators are worthless.
Bypass regulators will regulate from zero to the maximum pressure they are rated at so they will work with any carb.
Here is a pic of one of my tank jobs. Not much to see. Either the trunk or the spare hides everything.
I use 2 Stromberg 48 carbs. My block has 4 intake ports.
