35fordtn
Which pictures GM? I am honestly trying to figure out what you are referring to. The only senders I have ever seen or heard of in these years of Fords is the K-S units, like shown in post #27 above. None of them are the resistance type, they all use points that open and close to control the current flow. There is no way to take a resistance reading on them (except the base reading of the components). If you know of any other type ever used in Fords I would really be interested in what they look like and when they were used.
"Most were stuck in one position and we had to spray carb
cleaner in the resistor and work them until we got an ohm
reading of zero empty and about 30 ohms full or it may
have been 30 empty and zero full."
Can you post a photo of one of these?
The 36 and 40 wiring diagrams show the sender schematics with the points and heater coils.
J-Seery I too have only ever encountered senders such as those referenced in this thread made by King Seely. I own/have owned well over 200 of them and all original I have seen were of this type. I have not see this "Resistor" type other than when dealing with reroductions.
