Motorhead327
I looked and looked and found nothing that helped. I thought maybe if I drilled a small drill start in the end of the rods, I could fish them through using another small diameter rod inserted from the gearbox end.
Upon inspection of my rods, I saw both were ALREADY drilled on the end! Could this be the way the factory did it?
I used a .125" brazing rod, inserted in the lower hole and fished it through the upper column bearing hole. You don't even have to remove the bearing. You then take the rod and push it against the brazing rod, holding them both together. Then carefully push the spark/throttle rod against the brazing rod, letting the brazing rod slip in your hand, but keeping enough pressure to keep the ends of both rods together.
Two attempts...two successes.
