J Witt
This post results from my earlier thread about changing the spring pack for my roadster.
Once I have the spring reassembled, is it better to remount the spring on the shackles while the axle is sitting on the floor or is it easier to put the spring back in the frame and the raise the axle to reconnect the shackles?
I'm just thinking about getting the spring bolt reseated into the hole in the frame with the whole axle attached. I have read that most folks pull the rear axle for trans/clutch work and leave the spring attached to the axle.
John
John
