Ok, I will say that I made this just for fun, I was cleaning out a corner, it had scraps of this mesh, it was a 5min play project, I don't see it being any advantage to properly poured and fitted Babbitt , i havn't tried it in any engines, perhaps when I am pouring next I will pour it then chop it out to see what it looks like underneath the surface.
The method of bonding to the block, or cap is a factor in the thickness of the babbitt.
If the Babbitt is mechanically bonded the thickness is strength, but it also has to be supported, it is much like an insert, it has to fit the bore of the bearing, when it is cast in place it shrinks as it cools and has to be expanded to full contact with the bore ,when it is chemically bonded(tinned)the babbit can be thin because it is supported by it's bond to the substrate ---wether it is a cap like in the "A", or a modern insert, this along with proper material, temp of pour,and cooling is what makes a bearing that is very hard to hurt---no matter what you do to it ---I have tried to break the babbitt in my car, from all day driving flat out to 5mph for hours in 3rd going in a circle---even having an out of balance condition hasn't caused a failure---yet
My Brother thinks the Babbitt won't flow and bond to the mesh , I think it will.
