old51fordman
It is time to add more fluid to the 2 hydrostatic gauges on my '33.
They were relatively easy to fill appropriately at restoration as the gas tank and radiator were both empty. Over the years, there is, of course, some evaporation that takes place forcing the addition of fluid (what used to be called ox blood).
Reading the old service bulletin it sounds as though all that needs to be done is to remove the line and add fluid to bring both gauges up to "0".
It then sounds as though the fuel gauge will adjust itself while driving as the gas sloshes around in the tank allowing the the air pocket at the base of the "sending unit" to refill. The hardest part, it seems, is to get my old arthritic body twisted around so I can see and reach up behind the dash as it has to be done in place.
Am I reading that correctly or is there more to it?
If anyone has knowledge of this, I would appreciate the help.
Thanks
Thanks
