Typically a T's number will be found on the left-hand side of the block.
My '25 T hot rod has a number stamped into its frame, probably the only way to get it registered when it was first built.
My Rajo fairground racer has the VIN on the engine block.
If all you have is a body, it's very unlikely you'll find a VIN.
