I just redid the brakes on my 30 CCPU myself and the figure of $2000 is way too high. If you are any kind of mechanic, the parts will cost you: 4 cast iron drums = $1000, 8 new brake shoes= $256 and some odd and ends= $100. Your labor is not included and that includes arcing the shoes yourself (not that complicated). My truck will now stop as good as any car with non-power assisted brakes.
I find that folks sometimes want to compare apples to oranges in hypothetical situations like this. I believe the original poster's question was "
...how much does it cost to redo your whole brake system (original way) including cast iron drums?" in which my reply was $2k was a reasonable estimate if they are doing the work themselves. The key wording that I took to heart was the
whole system. Again, folks want to have great brakes but most mechanics choose to take many short-cuts to save money. Al, I am not arguing with you because you knew exactly what needed to be replaced on your truck's braking system however if we are going to restore ALL of the components back to factory specifications, -and do a quality job with quality parts, I do not believe your numbers are accurate.
I took the liberty to poll the prices of the two largest Model-A parts suppliers who in my opinion manufacture the best quality reproduction braking components. I have listed the majority of the parts that are required to restore the typical Model-A braking system. I think when most people look at this list and verify the pricing, they will see my estimate is not too far off. So we are clear, I find that most hobbyists that are rebuilding their own vehicle's brakes do NOT have all of the tools necessary to do the job correctly, and as such require assistance for restoration on certain components. Removing & installing brake drums is one such area. Most people do not have a large enough press, a lathe, nor a way to true the drums. The same can be said for accurately/correctly installing brake tracks or brake linings on shoes. Add in properly restoring a brake service brake cross-shaft or even front brake shaft components are items that make or break having quality brakes just like when the vehicle was brand new.
Now if we really want to split hairs in this debate, it is always easy to forget the incidentals that seemingly add to the cost too. For example, no one likes to factor in the cleaning supplies to clean the removed brake components, nor the costs of the masking tape & paint required to coat all of the new or restored parts, ...nor the bearing grease, or fasteners, cotter pins, and like supplies needed to do the job correctly. In addition, folks like to forget the expenses of boxing cores up for shipping (like 4 heavy brake drums & hubs, 4 brake housing plates, 8 brake shoes, etc., etc.) and then the costs of the freight for the restored cores & new parts to be returned. Again, I am not trying to step on anyone's toes or upset anyone but hopefully you will see that my answer above was based on real-world experiences and not just a fake number.
