Tinker
Again, I didn't mean to hijack the thread.
But yet, you are
But yet, you areSorry I'm not always polite... but at least you both are named Randy. That helps.
Looks like were both working on a very similar issue.
I have just replaced the coil. https://www.amazon.com/gp/product/B001CO4WA2/?tag=atomicindus08-20
I believe it's a 3.0 ohm coil. What setting should I use on my meter to measure the ballister resistor ohm?
If it is a 3.0 ohm coil you don't use a ballast resistor. Your looking for a total of 3.0 ohms, 1.5 ohm coil + 1.5 ohm ballast resistor OR a 3.0 ohm coil.
