Personally, I would regard this type of purchase as in investment in shop-equipment that can / will be used on other vehicles, and should last a lifetime.
Therefore, I would be inclined to shell-out a few $$ for something decent ( ie: Craftsman, K-D, Snap-On, etc.)
I would shy away from really cheapo stuff from Harbor Freight or other bargain crap, but others will disagree...
When it comes to tools and especially measuring equipment, you usually "Get what you pay for" in terms of durability and accuracy.
I like the compression testers that come with a flexible hose and have a check-valve that keeps the needle on the highest reading until you press a little release-valve on the side. Most kits of this type come with a variety of adapters for 10mm, 14mm and 18mm spark-plug ports. You will either have to purchase a 14mm to 7/8" adapter from one of the model A suppliers ( they run about $6-8 ), or make your own out of an old 7/8" spark-plug shell with the porcelain broken-out and tapped for 14mm or with a 14mm "anti-fouler" welded in to the 7/8" plug shell.
Good luck !
SC Frank
