mumpsimus
My 37 could use a little more torque and hp when hauling the family around. It is a stock 21 stud, with rebuilt carb, distributor, and fuel pump. I don't want a hot rod or loud pipes, and don't want to pull the motor from the car. It idles well, is quiet and runs smooth. I'd like to keep all that, but with a touch more oomph when I step on the accelerator pedal. If it could go up from the stock 85hp to say 105hp that would be nice.
What do you guys recommend? Simply mill the heads for higher compression? Or buy aluminum heads, or instead buy dual carbs, or a cam, or something else?
Is any modification recommended over the others?
thanks in advance,
Pete
thanks in advance,
Pete
