Burt Lake Barn
I put a 1949 8BA flathead with an Edlebrock intake and three Holley 94’s in a 1947 Ford pickup and attempted to use a typical ford accelerator pedal and push rod to operate the center carb. I have a good progressive linkage from a reputable source on this and the carbs all open up correctly but the mechanical (pull) pedal linkage does not give me enough throw to fully open the carbs with the pedal to the floor. Suspect the firewall distance to center carb is different so I want to switch to a cable type system, replacing the old foot pedal mechanical system with something that will get me the throw I need. I’m looking for a recommendation on a product and a source, that someone may know of that is adjustable and will work with my flathead. Would love to find a single source if possible to get the pedal, cable and associated brackets that I will need. I’ve been looking but there seems to be endless components available to choose from but I’d like to find something that will be somewhat designed for and proven out for my flathead application. Advice, ideas or practical experience will be greatly appreciated.
