howie123
On a recent drive in my Model A speedster, the clutch release arm broke. I understand this is not uncommon but I may have initiated the problem when I installed the arm with a reproduction pin which I believe was probably too tight. I got a new arm and pin from Snyders. It is the slightly longer version. I was more careful with the installation and all is fine. I couldn't believe how much easier the clutch works. When they say 30% decrease in pressure, I think it's true.
Now for the question. The speedster has a stock 28 engine, Zenith carburetor, electric fuel pump with regulator. It starts easily and runs great. When I get up to speed it does make an occasional spittiing noise and I get black sooty spots on the right rear wheel and right side of differential. Is this a matter of running rich? What would be the most logical things to start checking. Thanks. Howie
