George/Maine
Now your valve timing is good your ign is out 180
Guys I think I found it!! Here is a pic if I can get the darn thing to load.... interestingly enough the cam gear is almost exactly 180 degrees off from this dot. For some reason pictures are rotating 90 degrees on me when I upload them to this site. Doesn't do that on the HAMB?
you may have washed the oil off the cylinders causing low comp.if your sure cam timing and ignition timing are correct pull the plugs makr sure they are dry.oil the cylinders and try pull starting it ive done it many times to get one going.
