Thanks to all you guys. I bet I can beg/borrow the tool from one of the EFV8 guys
Thanks again
To remove the imulsion tube, use a #6-32 tap....did quite a few with 100% success...so far. I also soak the carbs in a solvant for a day before pulling out parts and even jets....gauled up threads once....bad move doing it dry. Most important, stay away from the cheap kits...bad deal...stick with the 'real' new Stromberg replacement parts. Robert
6x32 tap is correct. Simpler way is run tap in jet end,leave tap in there and from other end slide in a round steel rod and just tap with a small hammer and emultion tube and tap will all come out . Just make sure they go back in with all the holes faceing the rite way. Carfully check the 2 or 4 holes are NOT squashed down. They can be redrilled with a small bit.Same size as the others on the tube. No need for washers and screw as some guys use.The end holes get mashed when the MJ is tightened too much. ken ct.Your also going to have to modify a flat blade screw driver with a cut-off wheel slot cut in the middle of it to remove the power valve and not push the PV pin downthat sticks up down there. good luck. ken ct.Here you go. Max's tools are the air compressor blow out thing and jet wrench. My Mick the Mope tool is what I made to pull out the emulsion tubes. As Robert stated, tap them with a #6-32 thread. Thread in bolt and pull them out.
You'll need to remove the jets first.
Thanks Tim, I got a members help and expertise already lined upDo you have a tap set? If so, it is very easy to make an elumision tube puller. I also have Max's air compressor blow out tool and his jet wrench that I'd lone you.
I'll take picts. of the elusion tube puller I made. I forget what tap I used, but I'll figure it out after measuring the thread/pitch of it.
As JWL said, a lot depends on the condition of your core. Uncle Max has offered before (I didn't take him up on it yet) to machine my Stromberg parts and get them ready and send them back for me to assemble.
It seemed like a good middle ground of not paying full boat for a rebuild yet, still having a hand in doing as much as I can on my rebuild.
Let me know if you'd like to borrow my Stromberg tools and I'll get them out to you on Monday.
Tim
What is the brass tool in the middle between the Jet wrench & emulsion tube puller ?
Thanks, Russ
Its a blow out adaptor that screws into the PV hole [after its out] that blows out the 2 curved squirters of any junk. Uncle Max makes and sells them. I have one works perfectly. Theres no other way to clean them out.You cant poke a wire through them too much curve to them. Believe me ive tried.Use a rubber tipped blow gun tip to use it and hi pressure. ken ct. SUPER TOOL.What is the brass tool in the middle between the Jet wrench & emulsion tube puller ?
Thanks, Russ
