If youve never done one before its difficult,if you have its fairly easy. You need to have the rite tools with you. First remove whole carb from manifold. separate the base from the rest of carb.First the lft side throttle linkage must be removed,do not bend shaft by driving out the small taper pin.Need small drift punch. Then remove the 4 throttle plates screws,remove butterflys [they are 1/2 mooned stamped on one side so make sure they go back in the same way] Then you can slide shaft out of the base. Now you have the bare base with the 2 pc assembly that you have to change,unfortunally its sits behind the bushing it rides on . The bush.+the lever assembly comes out as a unit by tapping behind the lever with an all steel screw driver and small hammer,keep at it it will all come out, Replace with new linkage and reverse everything you did. Not an easy job for a novis on the road. ken ct hope this helps. ken ct.
