Rebuilding OEM shocks
Here is what I did:
Core is disassembled, cleaned, inspected, new seals and stem packing installed, inner cover fitted, refilled with 85-140 gear oil, reassembled, resealed cover and stem valve, tested for function, adjusted, then painted. Then sorted to match a correct set of original functioning shocks, ROAD READY.
Very rusty cores at the beginning time to clean them and rebuild them
After a good cleaning. They look much better now and all the channels and valves are cleaned and working good
Thread sealer,installing 2 o rings, filling with gear oil. Adjusting the shocks
Rebuild and finished shock ready to use
Several shocks I am working on. I am putting together a correct set of late 1931 shocks
On work work bench are some single shocks I have rebuilt
Finished set of 4 shocks. If you need any let me know
