We have them in stock. This same assy was used on 1942-48 passenger cars & 1942-52 trucks. The bearing is the 21A-8626 and the impeller & shaft is the 21A-8639. We also have the gaskets.
This setup had no ball bearing or roller bearing. The shaft ran in the spindle bearing on a splash of oil. The factory changed their original spec from motor oil to 85 wt gear oil.
