HalcyonDays
Rebuilding a side bowl carburetor, and the lower body is giving me trouble. Both the Cap jet and the main jet(which broke off) are not coming out easily. I decided to add a little heat to see if I could loosen them up(no luck). While I was putting the torch to the body I notices flames shooting out of what seemed to be a small hole below the GAV in the casting of the lower body. Has anyone else experienced this? When the casing cooled down I could not see where the hole was. I put some penetrating oil in the passages and the oil did not find its way out. Wondering if I should find another lower body or if this one is still okay. Thoughts would be great.
