Ed in Maine
I have the following questions:
When assembling the rear axle, should gasket sealer be applied to both sides of multiple gaskets between the banjo and housings?
What kind of gasket sealer would be best to use?
What is the recommended minimum thickness gasket for the gasket on the right (passenger) side to get a good seal. This is the side that may only have one gasket.
When assembling the pinion gear to the drive shaft (this is on a taper), should I apply a coat of oil to the shaft to help the assembly? This same question would apply to putting on a rear brake drum.
thanks for your help. Ed
