Take all the abjustment out of the rear brake,remove the center nut on the hub and give it a good pull. If it stays on,go get a old fashion wheel puller that bolts to the hub,in your case bolt to the wheel. Also you can cut the lug nuts/stud off..there bad anyway.
Wick
